Electronic Throttle Valve
Old Sep 19, 2004 | 10:09 PM
andreas187's Avatar
Default Electronic Throttle Valve
Hi all, wondering if anybody can shed some more light on a problem I'm having with my Montero 1.8GDi. I get an error on my dash which diagnostics describe as a problem with the Electronic Throttle Valve Motor 1.
Do I need a complete ETV (£1,000!!) or can the 'Motor 1' be purchased seperately.
This is apparently a common problem???
Thanks in advance.
Andreas
Old Sep 20, 2004 | 02:01 PM
SpyderGS's Avatar
Default RE: Electronic Throttle Valve
Wow, we don't have any cars or suv's in the U.S. with GDI...Except for the mondo expensive BMW and Mercedes Benz V12's. I'd imagine you can buy the motor seperately though, installing it may be a problem if you're not into electronics. The best thing to do is get the part # for the motor, and do a part number search online. Currently, i'm not aware of any websites that lists equipment for non-U.S. engines, but i'm sure there are some sites out there. If worse comes to worse, ask the dealer to look up the part #. If the dealer says "you need to purchase the entire ETV", you should check with your local shop and see what they say. Chances are though, the motor will not be cheap. I hope this helps you a little, and good luck.
ronsin1
May 29, 2009 09:50 PM
Skiddy
Jan 11, 2009 02:16 AM
newguy2007
Jan 16, 2008 07:08 AM
dman20084
Jul 26, 2005 09:22 AM
