the engine keeps flooding
At this point I would look at a fuel delivery problem. You're getting spark to at least start the car, and from your first post, run it a short while. It also seems the fuel pump is starting and temporarily providing fuel. I don't know when the fuel filter was changed or how many miles are on the car, but if the fuel filter is old and within easy access, that would be a cheap and easy try. After that you'll need to test the fuel pressure. Will the car at least idle?
It smells like somethings burning. And yes as long as i keep giving it gas its ok. As soon as i let go of the gas*the car won't go idle. It just shuts off. And smells like somethings burning.
Just got the car back from the mits dealer. It still does the same thing every now and then. He did a full dianostic on it. Changed some gaskets and soem ball bearing? Not only is it doing this. The car keeps jumping in and between gears. Like the acceleration is off or something.
