engine light...
i took my talon in for an oil change shortly afterwards i got a check engine light and took it back to the shop and they ran dianostics on it and said it was engine code p0170 bank 1 which is a fuel bank error or somthing like that, and then they told me that they couldnt figure out which sensor was giving it or what was doing it anyone have any ideas? i have a temp inspection on my car and it wont pass NYS inspection until that light is off so feedback will be very appreciated
RE: engine light...
I beleive it is attributed to a bad front O2 sensor
RE: engine light...
Check your gas cap. Make sure it has the seal on it. Then check your vapor return line. Make sure it isn't cracked or damaged.
RE: engine light...
Agreed with TE
RE: engine light...
could a vapor problem cause it? because i noticed that when i open my gas cap it has a SERIOUS pressure release
RE: engine light...
The pressure release is normal.
