-   Everything else (https://mitsubishiforum.com/forum/everything-else-37/)
-   -   Fuel Pump Regulator (https://mitsubishiforum.com/forum/everything-else-37/fuel-pump-regulator-54806/)
Searley Dec 3, 2020 04:11 AM
Fuel Pump Regulator
Hello Fellow Mitsus Lovers,I have a AB Cordia GSR T,I had to replace the fuel pump and take out the fuel tank. Fitted a new fuel pump and installed the tank and now the fuel pump won't go unless I use a Hot Wire,someone said the Relay under the dash might be the problem.I've got the Haynes work manua and a Mitsubishi wireing manual but can't find any info on a fuel pump relay.Has Anyone got any Clues,Much Appreciated Thanks Searley.
