GSX..bad mileage??
Hey, I just bought a 1997 GSX and am not getting very good mileage. What is typical for these cars under normal driving conditions?
RE: GSX..bad mileage??
i average 24mpg between fillups 1/2 city, 1/2 highway, redlining every once in a while.
Highway only ive gotten as good as 32mpg when i drive like a pussy. This is all with 16g turbo, 680cc injectors, safc. The best ways to increase mileage are: 1. inflate tires on the high side (mine are kept at ~38psi) 2. new or good condition plugs/wires 3. make sure you have no boost leaks (no intake piiping leaks) 4. clean injectors In my experience mods have nothing to do with mileage and sometimes actually gove u better mileage, but if you have crappy mileage check the 4 things above. If those 4 are fine, you may want to do a compression test. If you have a bown head gasket or crappy compression your gas mileage will be bad. |
does it feel like the car is gettin enough air into it? cuz if it does then check ur intake, my friend John had ****ty ass gas mileage so he checked his intake n he found rocks in there....i have no clue how they got there but they were there. After he cleaned it out his mileage was better...so juss a thought, check 2 see if ur intake is clean or if there is nething in there.
Hey, I had my car checked out today and they said I had a bad air filter so they changed that and also the code read that my front o2 sensor was bad so I will have to order one of those today. Thanks for your help, I hope I get better mileage out of this car now!
| All times are GMT -5. The time now is 06:39 AM. |
