HELP !!!!!!!!!!!
I am trying to get my wifes rotors cut on her 98 Montero Sport. The local shop only cuts rotors OFF the vehicle and I can't get past getting the callipers off. I tried everything in my abilitiy to figure it out, but I need some help ... quick.
can someone detail me on how to get the front rotors off the truck. I took the bearing cap off thinking I could slide the entire ass. off the axle and that didn't even work. ARGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGG |
RE: HELP !!!!!!!!!!!
are you sure that the rotor is bolted on? i worked as a tech for quite a while and they can become galded onto the hub..try tapping around the wheel studs ON THE HAT of the rotor to work them loose. i dont recall if you have to remove the hub cap and take the nut out to get them off.
google is your friend. if the rotor is stuck an there are no more bolts to remove hit it with a hammer to lossen it.
