HELP!!! Shift/Transmission/Clutch Problem?
Well, my friend is stuck on the side of the road at the moment. Some help would be nice.
The Car: 1995 Mitsubishi Eclipse GST w/ 5-speed The car is stuck in the 3rd gear. When depressing the clutch, he can't get it to change gear. He can't obviously start the car, because it's in 3rd gear, and grinds. HELLPPP!!!! Thanks, Richard |
RE: HELP!!! Shift/Transmission/Clutch Problem?
Did you check the clutch fluid? A long time ago I had a friend with a jeep cherokee and we had the same problem. He had a leak, but it was slow enough that we stopped to put more brake fluid in whenever he would start to lose a gear, or get a little grindage.
