how to fix a 1999 eclipse side mirror bracket (passenger)
i need some advice should i fix it or replace it???
RE: how to fix a 1999 eclipse side mirror bracket (passenger)
are you talking about the bracket that is inside the covering for the mirror that the actual mirror is attached to. Because if it is i doubt youll be able to just get the bracket and if you did im not sure youd actually be able to repair it that way. I would just try and find the whole mirror at a junk yard and just replace it
