-   Everything else (https://mitsubishiforum.com/forum/everything-else-37/)
-   -   Instrument panel not lighting please help (https://mitsubishiforum.com/forum/everything-else-37/instrument-panel-not-lighting-please-help-2757/)
cess_king Dec 7, 2004 08:49 PM
Just looking for some help. I have a 91 eclipse gs, and i'm having trouble figuring out what's wrong with my instument panel. Nothing lights up except my check engine light. Nothing else works I replaced the fuse, and checked the bulbs. Any info on wiring problems very welcome.
96awd Dec 7, 2004 10:11 PM
RE: Instrument panel not lighting please help
what fues did you replace?in the car or under the hood? do your tail lights work, blinkers. if they dont work itsprobably your fuse in the engine bay.
99clipsgst Dec 8, 2004 01:03 AM
Same thing happened to me. Did the tail lights go out too? It's a fuse under the hood. Mine was loose so if you can't find a burnt out fuse wiggle some around.
1398spdr Dec 8, 2004 02:39 PM
did u recently install a stereo, if so, and if its not the fuse, check the wiring on it.......
