little help please
ok on my 98' eclipse i had the torson bi, or corsion bi, somethin like that snap on me, i need to find out exactly how to spell this part, and/or maybe figure out where to get it from, all i know its for the stability for the wheels, it was my right rear tire, so if any clues out their, please help me out, thanx
RE: little help please
I think you're referring to the rear trailing arm. Torsion bars are are something completely different and is NOT something found of the Eclipse. Good Luck!
Joel, CA |
Its either the trailing arm or the stabilizer bar. where does the bar go to? is it from the lower arm to the chassie(trailing arm) or does it go over to the other side of the car?(stabilizer bar)
hmmm not sure, i know what the tow mechanic dude said, he said its the the stability for the tire, its the right back tire, and now i can move the tire right and left, lol, that aint right for the back tires, not sure if that little bit of info helps
you could always take it off and take it to an auto parts store or the dealer and they should be able to def be able to tell you what it is
