elherron |
11-22-2011 09:59 PM |
mitsibishi eclipse camshaft
i have a 1993 mitsibishi eclipse 2.0 non-turbo. i recently broke a timing belt and bent all 8 of the intake valves, so i purchased one from a wrecking yard without the camshaft installed. prior to the camshaft going in, the valves were seated properly. however, once i installed the camshaft, the valves do not seat. my question is, do the valve lash adjusters need to bleed for a period of time before the vaves will seat properly? there is about 1/32 of an inch gap between the valves and where they seat. any help would be very much appreciated. thank you
