Mitsubishi Eclipse 2.4L Air Con
Old 05-15-2006 | 10:46 PM
atari_400's Avatar
Default Mitsubishi Eclipse 2.4L Air Con
Hi guys,
My A/C does not seem to be as cold as I think it should be, so I went and got it checked at a local garage.
They hooked up an AC tester, and they told me that I have 2.5% air in the lines and therefore there must be a leak. I told them it had been like this for a couple of months (I live in Florida so I get to use it more...).
Being as the AC temp has not worsened since I have had the car (since Feb), is their diagnosis correct ? Note I did not have any work done, just the check performed. I was expecting to just need a charge as the car went into service in 2004 so I did not think anything would have started leaking yet.
Cheers.
Old 05-17-2006 | 02:12 AM
Evil1993Eagle's Avatar
Default RE: Mitsubishi Eclipse 2.4L Air Con
Take it to a dealer and have them check it for leaks. If the a/c is blowing warm its because you have a low charge in your a/c system(leak).
Old 05-19-2006 | 04:40 PM
atari_400's Avatar
Will do.
One quick question though. If I do have a leak would the A/C start to get warmer ? It seems to be consistent just not as cold as I expected it to be.
Thanks.
Old 05-21-2006 | 01:34 AM
Yeah if you had a leak it would continue to get warmer.
Old 05-21-2006 | 01:36 AM
Another thing does the a/c switch on and off fast? Like every 15-20 seconds?
srdiaz
05-23-2015 12:11 AM
jvray@free.fr
10-28-2009 11:57 AM
keels
10-31-2008 10:55 PM
filou89
05-01-2008 04:17 PM
trixibelle67
12-17-2004 07:09 PM
