Modification of MR cluster to Gli lancer instrumental panel
I need help. Need advice from you guys out there.
I'm currently driving a Gli CE lancer 4dr 1.8L sedan. My car do not have a tachometer on the cluster, and recently i came across a good offer. A MR crashed and the owner is trying to sell all the working parts. This cluster has a tachometer on the left, speedometer on the center and fuel,temp on the right. The dimensions given is 32cm wide, 15.5cm high, 11cm bottom width and 6cm width. My car has the fuel meter on the left, speedometer on the center and the temp on the right. So was wondering whether any good advice on will the MR cluster fit into my instrumental oanel nicely. And if yes it does, is the connection for the tachometer be messy? Thanks to all who reply... |
| All times are GMT -5. The time now is 09:27 AM. |
