Need help with clutch
I need help asap. I was driving last night and I noticed my clutch start to slip, then I started to smell it, then I ended up on the side of the road with my clutch burnt out. So I was wondering what clutch I should get, I'm leanding towards the ACT 2600, and I'm not sure which fly wheel I should get, I probably will not resurface my flywheel, Thanks. How much will labor cost on this do you think also?
RE: Need help with clutch
depending on where you go for labor, itll run ya between 60-80 hour, figure about 4 hours, so probly about 300, give or take........ not sure though cause i get discounted rates.........
Just took it in it's a bout 1 grand, my friend who works on dsms a tons says that he would not recommend putting it in my self because, he did to his GSX, and TSI, and he said it was way to hard and he'll never do it again. I guess I just have to pay the money, I'm goin with the ACT 2600, and XACT Streetlite Fly Wheel.
wow, thats expensive............ when you get it done, let me know how much the flywheel helps out..............
