New Member... looking for advice
Old Oct 13, 2021 | 10:54 PM
Apollo11's Avatar
Default New Member... looking for advice
Ive been searching the internet for the answer to my question, and tho it would seem to be a common issue, I can't find a clear answer anywhere.
My daughter has a 2007 Eclipse GS 2.4L and the timing belts teeth stripped off at the crankshaft pulley so it lost timing.
My question is when i install the new belt, and i set piston 1 at TDC, how do I know Im at TDC of the compression stroke vs TDC of the exhaust stroke? If it was a wasted spark ignition it wouldnt matter, but it's a coil on plug sequential fire ignition (Im told).
I hope this makes sense, I keep getting the feeling Im missing something really easy and obvious, otherwise Id be finding other people asking the same question. Every how-to I find, including "broken timing belt repairs" all talk about setting the timing to the marks as if the old belt is still there.
Old Oct 14, 2021 | 03:04 PM
DibbyDibbyDJ's Avatar
It doesnt matter. As long as the timing marks are all aligned correctly when you put the belt on you are ok
Old Oct 14, 2021 | 04:27 PM
Apollo11's Avatar
Thank you for the reply. So i don't have to figure out which revolution the crank is on to time the spark to cyl 1, even with it being sequential fire?
Old Oct 15, 2021 | 03:11 AM
Yep that is correct. The camshaft sensors in conjunction with the crankshaft sensor sorts that out
Old Oct 15, 2021 | 11:09 AM
Apollo11's Avatar
fantastic, thx. I hope this thread helps the next guy wondering the same question.
PS- hey next guy- you do have to make sure the oil pump sprocket is on the correct revolution- 14mm bolt under the manifold procedure, it's on YT.
The next guy will probably be me again in 3 years.
Old Oct 15, 2021 | 02:12 PM
Apollo11's Avatar
I have another question...
I lined everything up, installed belt, made the mistake of installing hydrolic tensioner before doing 2 full revolutions to get rid of slack. Now everything lines up except my oil pump sprocket, its mark moved from 11 oclock where it started, to about 7 o'clock.
Do i need to start over or will i be ok?
EDIT Nvrmnd, i did a couple more pairs of rotations and everything's ok.
mountaincycle
Mar 7, 2016 08:50 PM
golo
Nov 16, 2011 09:34 AM
dissturbbed
Oct 4, 2009 05:22 PM
wrench1
Sep 7, 2008 12:54 PM
mikenacarato
Mar 28, 2005 02:44 AM
