-   Everything else (https://mitsubishiforum.com/forum/everything-else-37/)
-   -   No Start (https://mitsubishiforum.com/forum/everything-else-37/no-start-34269/)
Revv777 Nov 1, 2009 12:24 PM
No Start
I have a 1994 Mitsubishi 3000gt SL. It currnetly will not start at all, it just keeps cranking. It has fuel, spark and injector pulse. The timing belt is good and lined up correctly. I don't know what, if anything can cause this. Anyone have ideas?
dsm1990gsx Nov 1, 2009 04:40 PM
Check for compression.
TheEngineer Nov 1, 2009 06:11 PM
does it crank slow or normal?
Revv777 Nov 1, 2009 09:15 PM
It has compression and cranks normal. It sounds like it wants to start but just doesn't.
dsm1990gsx Nov 1, 2009 10:48 PM
Did the car run before then just die?
Revv777 Nov 1, 2009 11:51 PM
Yea, it ran fine until I took it to the car wash. I'm thinking that its the crank sensor cause I sprayed the wheels good to clean them up and it was missing the wheel well covers. I was hoping to get some additional input though. I would think that the crank sensor regulates spark and if its bad there would be no spark, but i'm not sure. Is there any other explanations?
dsm1990gsx Nov 2, 2009 07:44 PM
How strong is the spark? If its weak that may be your issue.
Revv777 Nov 2, 2009 07:52 PM
It's fine. I actually put new plugs in it because the old ones were fouled.
Revv777 Nov 5, 2009 09:32 PM
Well, I'm going to assume since nobody can figure this out, I have missed something somewhere. I'm going to start from scratch and go through a no start flow chart again to verify my results. I'll post em up in a few days.
TheEngineer Nov 6, 2009 06:12 AM
yea i mean you pretty much got me stumped on this becuase it seems you have all the things needed to start, yet it wont
