-   Everything else (https://mitsubishiforum.com/forum/everything-else-37/)
-   -   Oil Pressure Light (https://mitsubishiforum.com/forum/everything-else-37/oil-pressure-light-1175/)
quinny May 13, 2004 05:53 PM
Oil Pressure Light
A couple days ago my oil pressure light started coming on. The light only comes on when my car is warm and only when I am stoped and at my low rpms around 700, and the second I hit the gas or raise my rpmsby about 100 it goes off. I checked the oil it was where it should be and I did an oil change about 1k miles ago. Anyone know what the problem might be.
91eclipse May 14, 2004 05:00 PM
Oil Pressure Light
i dont know my old 91 did the same thing at low rpm's. i still dont know what was up with that.
SpyderGS May 17, 2004 11:15 PM
Oil Pressure Light
Lack of flow, something maybe be *choking* the oil supply at low pressure(engine idle). Could be something as simple as a dented oil pan. Not a problem, but it can be annoying. What oil filter did you use?
crash May 17, 2004 11:55 PM
Oil Pressure Light
oil pump might be going out
Mitsu-Tech May 18, 2004 12:19 AM
Oil Pressure Light
do you have and clicking sound in the top end of the engine ? </P>
any oil leaks? any little puddles at all under your car? ..the sending unit could be leaking ..at idle you will get false readings your best bet is to hook up an external oil pressure guage to get true readings can use an after market guage or rent one from a place like autozone for a few bucks ...after you get your readings repost your findings</P>
how many miles did you turn on the odometer </P>
GameOver99 May 21, 2004 05:03 PM
Oil Pressure Light
if you hear no sounds i wouldnt worry about it.</P>
Mitsu-Tech May 21, 2004 07:20 PM
Oil Pressure Light
<IMG src=smileys/smiley13.gif border="0">
Mitsu-Tech May 21, 2004 07:23 PM
Oil Pressure Light
Kind of Makes you wonder why they called them Idiot lights
LeapingGnome May 27, 2004 04:01 PM
RE: Oil Pressure Light
Same thing on my 94 Galant once I hit about 160,000 (now at 182,000), oil light on when warm at idle, hit the throttle and it goes off. Mechanic just said the seals are getting old, doesn't keep the pressure up as well at idle, but it's nothing to worry about. Haven't noticed any of the problems you mentioned Mitsu-tech.
EclipseGSRoadRacer Oct 5, 2004 05:59 PM
My idle is ok at idle, but for some reason it's right at or a tiny bit below normal when it's at 3000rpm after it's warmed up. THe oil pump is dented a little. How low is the strainer for the oil pump in the pan?
