Over-heating
When im driving my car is fine, but when im idling or parked, my car starts to over-heat until i give it some gas. Any ideas?
RE: Over-heating
It sounds to me as if your thermostat isn't completely opening. Cooling off after giving it some gas could mean that the water pump is forcing coolant through.
Check your rad fan and be sure that it is kicking on. Also, be sure that you're using a 50/50 water/coolant mix and not using more coolant than water. The coolant part is the lubricant/protectant, the water is the part that extracts the heat. So, check thermostat...hell, just change it, they're not expensive, neither is the coolant. Also be sure the fan kicks on when the temp gets hot enough to turn on. |
RE: Over-heating
if its only at idle, its most likely a fan problem, when your car starts to overheat, have someone look to see if your fan's running, but dont leave the car running too long or it will overheat and cause probems
RE: Over-heating
thanks guys, im changing out the thermostat tomorrow. and the fans were coming on when it came to temp and i was using 50/50. so hopefully the thermostat with fix it.
RE: Over-heating
I changed the thermostat out and it has fixed the problem. Thanks for your help!
RE: Over-heating
Good to hear. Thanks for letting us know
RE: Over-heating
Thanks for the update and glad to hear that the temp issue is resolved.
