questions on 95 eclipse na powered
i have a 95 eclipse 5 speed, n/a powered. i recently blew either my clutch or my tranny itself. idk bc i i havent brought it in yet to get look at. well i was wondering while they have my tranny out what parts should i replace and what should i replace them with? i have plans on eventually turbo charging it. prob. a t3/4 turbo.
-i was thinking a stage 3 clutch and a new flywheel. but idk if stage 3 clutch will be over kill for a n/a powered eclipse. - and if it is my whole tranny, what would be the best tranny to go with? > could i put a gs-t tranny in it? or would it have to be a n/a 420a compatable tranny? is it possible to put a 6 speed into it ? think some what money conservative.. i am only 19yrs old, but i do have some money to play with and when i do things i like to do them the right way the first time. thank you all for your help :) |
RE: questions on 95 eclipse na powered
Well i had assume u have the 420a engine? I'm stuck in the boat of turboing it to. And in order to do this you hafta do alot of fine tuning and upgrades. Theres really no cheap way in doing this. I'd go ahead and upgrade your clutch tho while your tranny's out.
stage III I assume it is the SS 3 or spec stage III that would prb. be to much but if you plan on Turbo soon go for it.
You dont want a 6 speed there is nothing spectacular about them at all it means you gotta shift 1 extra time thats it. And no I am pretty sure a GSt tranny wont fit since the motors are completely different. I think you stock tranny will be fine as long as you have a good clutch I mean ACT 2100 I think it is would work great not sure if they make it for the 420a but just an idea |
Better to do it now, then not and regret it later when your replacing it again...
