rs stalls and not codes found
Old Aug 1, 2004 | 02:26 PM
ninja_zx7r's Avatar
Default rs stalls and not codes found
well here goes the car is a 95 rs the car will start find after idling for a while i guess once it warms up the car will have a very rough idle to a point where if you dont hold the pedal it will stall and if the ac kicks in forgetted also set codes like 12 13 55 cant find them on the service manual any ideas will be great
Old Aug 2, 2004 | 10:52 AM
wildwest's Avatar
Default RE: rs stalls and not codes found
have you changed anything lately?
Old Aug 2, 2004 | 07:39 PM
ninja_zx7r's Avatar
i put a idle control sensor that it didnt help and the computer which the car didnt have
Old Aug 2, 2004 | 07:41 PM
ninja_zx7r's Avatar
i replaced the idle control that it dindt help and the computer
Old Aug 3, 2004 | 02:20 PM
wildwest's Avatar
here are the codes... and what they mean. sounds like an intake problem.
http://www.troublecodes.net/mitsu/
Old Aug 6, 2004 | 02:11 AM
ninja_zx7r's Avatar
thankyou ,one thing that it was doing also was that after idling for a while it will not hold the idle and you will have to keep tha gas pedal so it wont stall and if you give gas it will get to 3000 rpms and shut off kind of what a rev limeter does but today i drove it and it didnt do anything,could it be that the computer need it to re learn driving condition to stop acting out?
Old Aug 6, 2004 | 02:59 AM
thewilltolive's Avatar
tighten the throttle cable?
Old Aug 6, 2004 | 10:14 AM
wildwest's Avatar
they say a computer needs some time to learn its surroundings. But if it keeps acting up id check to make sure all the sensors in the intake are working properly. Have you changed any part of the intake or exhaust lately?
Old Aug 24, 2004 | 05:47 PM
1398spdr's Avatar
u can also unhook the battery from the computer and let it reset itself, just make sure you have the code for your radio. let it sit for about an hour, hook it back up and let it idle for 15 min, worked on my 98 spdr.
Davie-h
Nov 11, 2013 01:25 PM
membreya
Apr 18, 2013 12:50 AM
96galantS
Jun 2, 2005 04:55 PM
girlgetter
Sep 1, 2004 11:08 AM
