-   Everything else (https://mitsubishiforum.com/forum/everything-else-37/)
-   -   Sagging door (https://mitsubishiforum.com/forum/everything-else-37/sagging-door-33833/)
djailer Sep 20, 2009 01:34 PM
Sagging door
1 Attachment(s)
Can you tell me if this door part is likely to be causing my driver's side door to be sagging? The mounts on the tip hinge might be a tiny bit loose, but the crack in this also makes me wonder. It doesn't seem to be that much of a weight bearing point but....??? And what would you call this?? I have searched near and far and don't even get a lot of results searching for just 'door parts', 'door hinge', or other reasonable facsimiles.
Thanks
D.Cycle Oct 10, 2009 12:46 AM
Sagging door
Is that supposed to be some kind of mist on the other side of the door? Cant say that this does scary for me. Maybe less light on this side of the door and a bit more detail in the mist.
djailer Oct 10, 2009 01:59 PM
??? I am talking about the part right in the center with the pin going down through it. Are you sure you got the photo to open OK? I don't see any mist??
MacGruber Oct 16, 2009 08:38 AM
That is the door check, and no, it's not supposed to be cracked. A sagging door typically means the door hinge bushings are worn. This is what is causing your sagging problem. The picture illustrates what I mean.
http://carphotos.cardomain.com/ride_...0033_large.jpg
