sluggish at 3grand and higher ?
Old 10-26-2006 | 03:58 AM
g1bishi's Avatar
Default sluggish at 3grand and higher ?
my 1991 1g eclipse 2.0 started runnin bad at 3 grand or higher it seems too lose all power i checked the plugs wires maf and intake for air leaks. when it happened it jolted and started to miss and when you hit about 3 grand it almost sounds like it starving for air or getting too much any help?
Old 10-26-2006 | 11:28 AM
Default RE: sluggish at 3grand and higher ?
did you replace the plugs and wires because thats what it sounds like to me. Sounds like your car is misfiring. Does it still do it if you slowing go up in the rpms too or only when your flooring it
Old 10-26-2006 | 01:39 PM
I know what this is....... COME ON ENGINEER!
Isnt it those 2 little plastic rivets under the hood?
Old 10-26-2006 | 03:46 PM
ORIGINAL: Sebba
huh, are you talking about the thing on the intake, ist that on the 3g's
Old 10-27-2006 | 02:56 PM
g1bishi's Avatar
i found the problem my timing belt jumped teeth on the cam gears how it did that i dont know but its fixed now
Old 10-27-2006 | 03:05 PM
your lucky that the valves didnt hit
Old 10-27-2006 | 03:09 PM
g1bishi's Avatar
yea im about to send this car packin i have another 90 1g with a 1.8 alot slower but alot less problems thanks for the help
mightymo
06-15-2006 02:38 AM
jeffery0266
01-26-2006 07:18 PM
jeffery0266
01-26-2006 11:07 AM
mtalma
12-11-2005 05:52 PM
dsagal79
05-28-2005 07:17 PM
Quick Reply: sluggish at 3grand and higher ?
