Starter for an 05 Eclipse
Just wondering how complicated it is to install a starter on these cars. If I had to bring it into a shop would it be an expensive fix?
Thanks! |
i beleive a starter install will cost you around $300. From what i remember paying. May be a bit more. And can be alittle tricky to install yourself if you dont have all the tools and space to work. Is this a v6 or 4 cyl?
4 cyl.. Thanks
The problem is that the starter sits right between the engine and the transmission. If you have jackstands, and a good tool set, you should be able to change it in a few hours.
