Starting problem help
I just bought a spyder gst today and when i start the car sometime(not all the time but every once in a while) it will kind of die out when i start it like it would if the battery was dead but then i just turn the key back and start it again and it starts fine
any idea what the problem is? also, it has been lowered so it has the lowering springs on it but can i raise the car back up with these or do i need new springs? [align=left] [/align] |
RE: Starting problem help
Why would you want to raise the car again?
Change your spark plugs with NGKs, nothing else. Also get yourself some factory Mitsubishi spark plug wires (nothing else) and you should be fine : ) |
i need to raise it because in my town there are a lot of bumps and hill and it will rip the bumper off.
you would need new springs
Does it have a bodykit?
check fuel pressure may not be getting full prime when you first turn the key.
| All times are GMT -5. The time now is 10:01 AM. |
