-   Everything else (https://mitsubishiforum.com/forum/everything-else-37/)
-   -   Steering column (https://mitsubishiforum.com/forum/everything-else-37/steering-column-18190/)
Dusty Eclipse Apr 19, 2007 04:03 PM
RE: Steering column
Huh????
Adam Ravesloot Apr 19, 2007 04:03 PM
Steering column
Has anyone had any experience with the steering column in a Lancer detaching? The car still steers so it must be the adjusting mechanism but any experience or advice would be appreciated before the mechanic gives me a bid.
Thank you!
50ul }{4ck3r Apr 19, 2007 04:05 PM
RE: Steering column
are you talking about the Plastic cover around the steering column
Dusty Eclipse Apr 19, 2007 04:43 PM
RE: Steering column
Ive never heard of those breaking... if it does... I doubt its an easy fix. It may be stealership time.
Adam Ravesloot Apr 19, 2007 04:43 PM
RE: Steering column
I believe it's the plastic around or something that controls the adjusting part of the steering column.....to move it up and down.
50ul }{4ck3r Apr 19, 2007 04:45 PM
RE: Steering column
YA the stealership or a junk yard of heaven
Adam Ravesloot Apr 19, 2007 04:45 PM
RE: Steering column
Now it drops down and there is no control or locking when I try to move it back up or into place.
50ul }{4ck3r Apr 19, 2007 04:47 PM
RE: Steering column
the leaver to adjust the height of it up and down...is that what your talking about
Dusty Eclipse Apr 19, 2007 04:47 PM
RE: Steering column
You may have to manually lock it.. have you like sat and screwed with it?
50ul }{4ck3r Apr 19, 2007 04:48 PM
RE: Steering column
maybe someone broke it adjusting it...just find a junk yard or dealership
