4g93 gdi problem
4g93 gdi problem
Hi all, im new to this forum and I have some issues with my lancer.
any help would be much appreciated. car has a 1.8l 4g93t gdi engine. two days ago whilst driving, the engine check light came on and car started stalling. i turned the ignition off and then on again and the problem stopped. it was then taken to my mechanic where the engine was inspected, which showed an oil leak coming from the camshaft cap gasket and dripping onto the spark plugs. the leaked was repaired but the engine stalling persisted. the spark plugs and coil packs were replaced and engine was turned on, but shut down after 5 seconds. the engine was turned on again with air flow sensor removed and worked perfectly fine. the sensor was re-connected, engine turned on with no luck. any suggestions?
1590gilbert
02-24-2023 03:43 PM
Harv
02-24-2013 08:36 AM
smokey mcpott
03-10-2012 03:34 PM
