Trouble with trouble codes
Hi All,
I have an 03 Outlander. Been having a hard time trying to fix an Evap problem. Yeah, I know, what else is new? CEL is on, of course. Tank was out, small hole in top. Fixed that and it passed the smoke test. It's now throwing a code of P0456. Unfortunately the codes only go up to P0455 as shown below: P0440 Evaporative Emission Control System Malfunction P0441 Evaporative Emission Control System Incorrect Purge flow P0442 Evaporative Emission Control System leak Detected (small leak) P0443 Evaporative Emission Control System Purge Control Valve circuit Malfunction P0444 Evaporative Emission Control System Purge Control Valve Circuit Open P0445 Evaporative Emission Control System Purge Control Valve Circuit Shorted P0446 Evaporative Emission Control System Vent Control Circuit Malfunction P0447 Evaporative Emission Control System Vent Control Circuit Open P0448 Evaporative Emission Control System Vent Control Circuit Shorted P0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction P0450 Evaporative Emission Control System Pressure Sensor Malfunction P0451 Evaporative Emission Control System Pressure Sensor Range/Performance P0452 Evaporative Emission Control System Pressure Sensor Low Input P0453 Evaporative Emission Control System Pressure Sensor High Input P0454 Evaporative Emission Control System Pressure Sensor Intermittent P0455 Evaporative Emission Control System Tank Detected (gross leak) Anyone have any ideas or experiences? Appreciate the help, Bill |
P0456 also relates to a leak from the Fuel Cap, or EVAP system problem.
Possible Causes: Missing or loose fuel cap Incorrect fuel filler cap used Fuel filler cap remains open or fails to close Foreign matter caught in fuel filler cap Evaporative Emission (EVAP) canister or fuel tank leaks Evaporative Emission (EVAP) system hose leaking Fuel tank leaking If you have assessed all possible EVAP leaks, then I would check the security of the fuel cap, or try a new cap. |
| All times are GMT -5. The time now is 04:26 AM. |
