what engine is this cylinder head from ?
hi all
i recently came across an an aluminum 16 valve mitsubishi 4 cylinder SOHC cylinder head with casting code G6 on it does anyone have any idea what it is and what years and models these were used on ? it also has the entire intake asembly on it with the throttle unit and also steel exhaust header i am curious to learn as i know little about mitsubishi engines thanks for anything randy |
RE: what engine is this cylinder head from ?
ok thats good thanks :D
i got this from there: Galant 1993 1997cc 4G63K engine 2.0L F.I. 16-Valve SOHC Expo (93-95), Galant (95-98), Eclipse (97-98) 1993-98 2350cc 4G64 engine 2.4L F.I. 16-valve SOHC 2.4L F.I. 16-valve SOHC Galant, Eclipse 1999-02 2350cc 4G64 engine 2.4L F.I. 16-valve SOHC Montero Sport 1997-99 2350cc 4G64 engine 2.4L F.I. 16-valve SOHC http://www.rpmrons.com/MitsHds.html#2.0 that is all the SOHC 16 valve 4 cylinder heads they list anyways, but it may not be all of them that mitsubishi manufactured so hmm.. what does anyone think ? also does anyoen know of any classifieds i may possibly be able to post these for sale or trade(for chevy car/truck parts) at ? as i need to get rid of these thanks! |
Where did you get them from?
hi,
get what from ? these parts, or the info ? the parts i got from my neighbor are you attempting to get at something by asking ? im confused ? ?? apparently(from what i gather so far) the mitsubishi guys dont know much about the mitsubishi engines either is it due to lack of identifying features/castings ? or ?? hum does anyone know much about these ? hum.. looks like i will probably have to strip these and turn it all in for aluminum scrap it all weighs pretty good, it will be a nice addition to the rest of aluminum stuff to take in, i was just hopig to find out if it was anything good or evne what it all was for/from exactly oh well. thanks |
I'd say if you can take digital pictures of them then try selling on e-bay.
ORIGINAL: Sanguinius I'd say if you can take digital pictures of them then try selling on e-bay. |
Im not trying to imply anything... Im just wondering, b/c where u got them from could have helped to indentify them... Did your neighbor have a mits? Just try to trace it back from where u got them from and where they got them from...
...the only way i can help is,
letting you know I brought in, one hundred and sixty two pounds of extruded aluminum today... ..and received $92. ..you will probly get $5 bux for it. ..good luck whatever you choose! ..i too... would check with where it came from... ..if i were to ever put myself in that position. |
| All times are GMT -5. The time now is 08:46 AM. |
