Wire diagram
Need wire digram for 2002 mirage. Put in a remote start and now my dash lights do not work. There does not seem to be a fuse just for them. My next step is to pull every fuse and look for a broken one. If I could get a FREE wire digrame I could figure it out.
RE: Wire diagram
i did this same thing to my old integra you probably didnt know it but you might have taped two wires together and i did it to and i had no dash lights but i didnt have a blown fuse either just replace the light dimmer swithed because when you tap any dash light wires they go straight to the dimmer because there all controled by it and when wires tap they blow the dimmer switch so just replace the dimmer and it will all work perfectly fine
