Exterior Talk about your rims, body kits, and other exterior mods here.
aftermarket headlights
Old May 12, 2007 | 11:02 AM
ProjectDrknss's Avatar
Default aftermarket headlights
Hi, I was trying to install my new aftermarket headlights on my 96 Eclipse and I encountered a problem. I know how to install the headlight, but the problem I'm having is: Where in the world do I plug the "angel's eye" or halo or whatever it's called into? Can anyone help me with this? I'd really appreciate it. Thanks.
Old May 14, 2007 | 03:29 PM
Lil Evo's Avatar
Default RE: aftermarket headlights
If they're like mine, they don't plug in anywhere. If you want them to be on whenever you're driving lights are on, wire the (+) into the constant and ground out the (-) to the unibody. Or, you can run them on a switch, which would require you to extend your wiring. You can run it from the battery (or into the ignition harness under the dash would be my suggestion) to the cabin, throw a switch in line, and then to the halo, and again, use the unibody to ground out the (-) wire.
Old May 14, 2007 | 11:10 PM
thnx a lot buddy, i appriciate the response. i finally got them to work xD. thnks.
Galantluver
Dec 6, 2012 02:37 PM
melvin da penguin
Sep 19, 2010 12:19 PM
XxM4n1aCxX
Aug 15, 2008 11:55 PM
Wingo171
4th Generation
Apr 14, 2008 09:41 PM
n5926g
Oct 5, 2006 08:49 PM
