Exterior Talk about your rims, body kits, and other exterior mods here.
Grills
Old Mar 18, 2007 | 09:55 PM
EmberSpyder's Avatar
Default Grills
So i desided instead of paying like 100$ to 150$ for those grill fillers on my eclipse; I am just going out to home depot and get some grating. Then cut it and paint it. I made the templates today. Has anyone else done anything like this that might have some segestions or tips?
Old Mar 30, 2007 | 04:36 AM
2nd g eclipse gst's Avatar
Default RE: Grills
ive done it, its a whole lot cheaper and works the same good luck!!! post some pics when ur done...
Old Mar 30, 2007 | 10:01 AM
Default RE: Grills
i used to actually make them for cars and sell them on ebay. They work fine. Also lowes sells large sheets of them which i switched to since it was alot easier because they werent bent like the grates at home depot. Cutting is a killer on the hands though
Old Mar 30, 2007 | 10:19 AM
NubianSithLord's Avatar
Default RE: Grills
This is for TheEngineer I am glad I read this post, I have a question how do you attach them after they are cut. I was going to order one until I heard you could just get the stuff from home depot. Do you have to take off bumper/ I have 03 so all I need is the one piece in the front.
Old Mar 30, 2007 | 04:31 PM
Default RE: Grills
well the 03 is alittle bit of a pain because you have more of a rounded opening than the 00-02 which is just a rectangle. But the best way to cut it would be to leave small tabs extra over what it takes to fill the hole. You know what i mean. Maybe like 3 on top and 3 on bottom. Then fold each tab over and drill small holes into the bumper. Then just use a small bolt, washer and nut and fasten it to it. Thats the best way to do it. The other alternative is a clear glue, but that looks like **** when its done. Just take your time measuring and cutting to get the size exactly right. Like i said though the 03+ is alittle tougher. Good luck
Old Apr 7, 2007 | 05:36 PM
WPSpyderGT01's Avatar
Default RE: Grills
thinking about making one myself now =D
Old Apr 8, 2007 | 05:11 PM
Default RE: Grills
yeah thats what i was going to do. I was going to leave little tabs around the outside and then attach it with self tapping screws and washers.
victor5455
Jan 14, 2008 02:28 PM
firstsuv
Jul 10, 2007 08:34 PM
nawgee
Apr 12, 2007 04:44 PM
letsstophere
Aug 5, 2006 12:05 AM
redeclipse
Mar 3, 2005 11:44 PM
