LED side marker lights replaced
Bought these from AUXITO for my 2009 Lancer GTS. My GTS came with some pretty boring white lights...which I've felt never really looked good. Been wanting to do something with them for years...and I'm not sure how I missed these...But they look great both off and on. The sequential flashing is a nice touch.
To install:
With your fingers tips, grab the front of the light (the narrow end closest to the front tire) and gently but firmly pull the edge. It should pop out. Unclip the light from the harness and make sure you drape the harness out side the fender so you don't have to go fishing for it inside the fender! The harness should clip into the new light one way, so clip it in. Before you reinstall, turn on your emergency lights to verify the light is working. Align the new light so the back (the wider part in that is closest to the door) is in the hole then push the front end of the light gently but firmly back into the fender. Done.
Took me 5 minutes to install both, gave the car a very modern feel
To install:
