paint help
OOK whats up people i wanna paint my valve cover and i know you have to hit it up with paint and clea coat *ive done this befor* BUT heres whee i ****ed up..what paint to clea coat mix should i use..i tried like a 60%paint 40%clear..and it turned out kinda nice ill post a pic at the end..Any help would be nice
in the pic i painted the intake and the valve cover [IMG]local://upfiles/11618/A51D36C1E9DB4E20848D27292CE4A914.jpg[/IMG] |
RE: paint help
You mixed the paint with the clear?? =/ does that works?
RE: paint help
Sorry to tell you, but your not supposed to mix the clear coat and the paint. Your supposed to apply the paint first. Then add the clear coat over it. What kinda paint are you using BTW?
RE: paint help
and why is that car have its air filter right next to the headers...lol....headers get hot
RE: paint help
He's not SUPPOSSED to mix em.... but he did..... im really kinda curious as it how it turns out... haha, clear is stupidly fragile at times.... it may crack... or it might just be the perfect paint... who knows
RE: paint help
what in God's name did you do to that intake? does it have another filter down where the cold air filter is suposed to be? I was thinking the same thing about the paint but i'm not a genious when it comes to paint so i didn't want to open my mouth and sounds stupid.
RE: paint help
i doesnt matter if he has a another airfilter at the end of that......that airfilter is just sucking in the heat from the headers....not a good idea
and would a car act weird with that much air being suck in....the engine |
RE: paint help
i just used engine paint with ceramic.....the one i got was a lot shinny
RE: paint help
What exactly is going on in that engine bay? What appears to be 2 filters... whats the story with the braided aluminum tube there?
RE: paint help
OOOOK i have time to post now..the deal with the intake i was bored and thought id try a dual intake just to see if it would work..it was on there for like a week..it does work..only problem it ****s up your idle,soo i was idleing at like 2krpm all the time [:'(]...and back to thepaint..i DIDN'T mix the 2 togeather..i went over it with some red spray paint then went over it again with less clear..but what i was trying to say was..i didn't use as much clear coat as i did spray paint and i was wondering was that why it started to chip like 5 months after i put it on..or if that normally the about of time that it will last
