RE: Side skirts?
ORIGINAL: 5star I mesured and the front bumper takes away 2" of gc. The rear bumper takes away 5" gc. The side skirts are just as low as the rest of the body kit . I lookd and dont think rivets will work because the body kit is to far way from the body. I could rivet the bottom of the side skirts but not the sides. Their was this white glue that was on 2 pieces of my side skirts that held really astrong I had to pry them apart so I wil probably use what ever that was. |
RE: Side skirts?
ORIGINAL: sk8dudety what do you its too far off the body??? it pressed right up against the side... |
RE: Side skirts?
i dont think it makes difference to them... just drill through the sideskirt and the metal, rivet it, then have them run a quick coat of bondo or glazing puddy over it, sand it, and mask it off and paint it... should be fine... it's a lot stronger than glue or tape
RE: Side skirts?
Would they paint the whole body kit with it mounted on the car if i drove the car to them?
RE: Side skirts?
they probably will...but make sure you get the WHOLE body painted
RE: Side skirts?
i thought you were gettin the whole body painted... if not then i would just bring the kit to them, tell them to paint it and mount it, they'll do all the work for you... and if it falls off they'll have to fix it
