1999 Montero Sport Power Windows
Old 09-27-2003, 09:51 PM
dbeaver's Avatar
Default 1999 Montero Sport Power Windows
<FONT face="Verdana, Arial, Helvetica, sans-serif" size=2>Power window fuse located in the engine compartment continues to blow. Have disconnected all switch panels in doors and fuse continues to blow. However, if I remove the window fuse located in the fuse panelinside the vehicle (assume this is the fuse to a window enable circuit activated when ignition switch is turned) or turn the ignition switch to the off position the fuse will not blow. This leads me to believe I have a wire shorted from the enable relay contact to the main control panel located on the drivers door. Have no idea the wire path or color or where the enable relay is located. Need help from someone familiar with this vehicles wiring circuit. </FONT>
roundigo
11-11-2016 12:12 PM
oasis
01-23-2005 05:43 PM
millerl513
08-04-2004 10:24 AM
morourke2@juno.
03-15-2004 01:53 PM
Kuma
01-28-2004 11:26 AM
Quick Reply: 1999 Montero Sport Power Windows
