abriviations, acronyms all you need to know
3KGT 3000GT
3/S 3000gt/stealth A/F Air Fuel (ratio) A/T Automatic Transmission ABS Antilock Braking System AFC Air Fuel Convertor AT Automatic Transmission BDC Bottom Dead Center BHP Brake HorsePower BOV Blow Off Valve CAI Cold Air Intake CARB California Air Resource Board CCA Cold Cranking Amps CEL Check Engine Light CKP Crankshaft Position Sensor CL Closed Loop CMP Camshaft Position Sensor CPS Crankshaft Position Sensor (CKP) CR Compression Ratio DAC Digital Analog Convertor DIS Direct Ignition System DSP Digital Signal Processor DOHC Dual OverHead Cam DSM Diamond Star Motors (Mitsubishi/dodge/Chrysler) ECU Engine Control Unit ECT Engine Coolant Temperature EGR Exhaust Gas Recirculation EGT Exhaust Gas Temperature EPROM Erasable Programmable Read-Only Memory EEPROM Electrically Erasable PROM EVAP EVAPorative emission control system FCD Fuel Cut Defencer FMIC Front Mount InterCooler FPR Fuel Pressure Regulator FTW For the win GS grand sport GST grand sport turbo GSX grand spot all wheel drive HO2S Heated O2 Sensor HP Horsepower HVAC Heating, Venting, Air Conditioning I/E/H Intake / Exhaust / Header IAC Idle Air Control (ISC) IAT Intake Air Temperature IC InterCooler IMO in my opinion ISC Idle Speed Control (IAC) ITC Ignition Timing Convertor LIC Lower Intercooler Pipe LSD limited slip differential LOL laughing out loud LMAO laughing my ass off LMFAO laughing my f***ing ass off M/T Manual Transmission MAF Mass Air Flow MAP Manifold Absolute Pressure MAT Manifold Air Temperature MBC Manual Boost Controller MFI Multiport Fuel Injection (MPI) MT Manual Transmission MPI MultiPort fuel Injection (MFI) N2O Nitrous Oxide NOS (Holley brand) Nitrous Oxide Systems NA naturaly aspirated (N/T = non-turbo) O2S Oxygen Sensor OBDI On Board Diagnostics I (95 cars) OBDII On Board Diagnostics II (96+ cars) OEM Original Equipment Manufacturer OL Open Loop PCM Powertrain Control Module PSI Pounds per Square Inch Rice deacals on cars, big wings, anything that was in f&f, 2f2f, tricef&toykof... the thrid one. RS rally sport SAFC (Apexi) Super Air Fuel Convertor SATAN Your local mitsu. dealer SFI Sequential multiport Fuel Injection Shens calling on shenanigans SOHC single over head cam SRS Safety Restraint System STB Strut Tower Bar (or Brace) TB Throttle Body/Timming belt TCM Transmission Control Module (Automatics only) TDC Top Dead Center TQ Torque TPS Throttle Position Sensor TT Turbo Timer UIP Upper Intercooler Pipe UDP Under Drive Pulley WTF What the f*** WOT Wide Open Throttle Cyl 1, cyl 2, cyl 3, cyl 4, ect.- number give to a piston/combustion chamber dictated by the line of the fuel injectors, example: the first fuel injector that gets fed gas from the fuel line would be feeding cyl. 1, the last injector in the fuel rail that’s at the end by the shared valve feeds cyl 4. 14b, 16g, 20g, evoIII16g, big 16g, small 16g, 12g, T3, T4, t3/t4, GT28R GT35R ect... are all turbos I would like to thank my boys: superinflamo, oldskoolturbo, theengineer, sebba, davidmitsurock, 00marage, and a big thanks to Juan Laguna. please add to this list if you feel its important |
RE: abriviations, acronyms all you need to know
since i cant frickin copy and paste in posts anymore here is a killer list of things....
http://www.3si.org/wiki/index.php/Acronym_List |
you left out the all importantmivec abreviationlolthis is a mitsu forum right (Mitsubish Innovative Valve timing and Electronic Control system) just thought I'd add the best one
:eek:ECI electronic controled injection
DGAF- don't give a ****
My wife, three daughters, and other family members are now using Renewed Life acai berry Supplements, and love me for it. I am 68 and feel great.
DILLIGAF....does it look like i give a **** thats my favorite
Yes! I agree,you left out the all importantmivec abreviationlolthis is a mitsu forum right (Mitsubish Innovative Valve timing and Electronic Control system) just thought I'd add the best one......
Do not forget also BBW
Good one mate,
Thanks |
| All times are GMT -5. The time now is 01:14 AM. |
