-   General Mitsubishi Chat (https://mitsubishiforum.com/forum/general-mitsubishi-chat-5/)
-   -   ABS & TCL on mits Diamonte (https://mitsubishiforum.com/forum/general-mitsubishi-chat-5/abs-tcl-mits-diamonte-45215/)
rjschwing Sep 20, 2013 07:18 PM
I have a ABS & TCL on my dashboard on my 2002 Mitsubishi Diamonte. I replaced both the front wheel ABS Sensors but both lights still come on. What else could it be beside maybe the back ABS sensors that are very expensive?
thanks!! :cool:
Scotty in NZ Jan 22, 2017 05:51 AM
Both ABS & TCL systems are linked (i.e. they work in tandem with each other).
After replacing ABS components, you must follow the "Fault Code (DTC) Erasure procedure" to reset the ABS & TCL computers.
Disconnecting the battery does not reset the ABS/TCL computer.
A suitable ABS scan tool may do this, but there is also a procedure written in the service manual to do this manually without a scan tool (involves turning key to ON and depressing brake pedal a few times, in the correct sequence).
