CV JOINTS
Old Nov 20, 2007 | 12:10 PM
athlete1012's Avatar
Default CV JOINTS
Would bad CV Joints cause vibration in steering wheel. I am begginning to hear a squeak when I turn my steering wheel left. I check power steering fluid it was okay.
What cost should I be looking at if I have to replace CV Joints don't want to get taken advantage of. I have a 98 galant
Old Nov 20, 2007 | 08:28 PM
dsm1990gsx's Avatar
Default RE: CV JOINTS
I have never heard a c-v joint causing a vibration. When the boots rip they leak all the grease out and click when your making a turn.
You can buy axles for like $45.00 each and if you do it yourself labor is free. A shop might charge close to $200.00 for everything for one side.
Old Nov 21, 2007 | 10:32 AM
nick_200321's Avatar
yea cv joints wont cause vibrations just popping when you turn.. i dont know what the squeeking would be.. are the vibrations only when you turn?
Old Nov 22, 2007 | 11:34 AM
ComposeEvo's Avatar
If it's squeaking with you turn, and you power steering is up to par, then check your belt and the tensioner. At worst it's your pump. It's definitly not your C.V joints.
Gus
Old Nov 22, 2007 | 09:50 PM
dsm1990gsx's Avatar
For the squeak you might have something tight in the suspension/steering area. I have see a lot of outer tie rods get tight andsqueak when u turn the steering wheel. Just an idea.
OldSchool
Sep 5, 2006 10:50 PM
3000gtkid1119
May 18, 2006 02:51 AM
WIECLIPSEGUY
Feb 16, 2006 02:13 AM
bobdilts
Mar 7, 2005 06:05 PM
Customshiftboot
Jul 29, 2004 05:17 PM
