help mitsubishi galant problem fault code 44
Old 10-07-2008, 04:13 PM
cheesemcqueen's Avatar
Default help mitsubishi galant problem fault code 44
I have a mitsubishi galant 2.0 GLX year 2000. The engine light came on the other day and the car dropped down to 2 cylinders. I've changed the plugs, leads and electronic coil to no avail. I got it plugged in today at mitsubishi dealer and they came back with low ignition feed problem, fault code 44, but couldn't pin point it. Saying it could be anything from battery, alternator or a loose wire. Any ideas? I did have the cam belt changed just before the fault started, my mate who is a mechanic had to move the crank sensor to do it and thinks it could be this, any feed back would be greatfully recieved
Old 08-20-2018, 09:54 AM
Fredi's Avatar
Default Hello dear
Hello
can u help me pls i got a same problem
after belt change
ashraf
08-27-2009 09:38 PM
cheesemcqueen
10-07-2008 03:57 PM
3000gt123
09-22-2006 04:45 PM
3000gtyeah
08-17-2005 08:22 PM
Quick Reply: help mitsubishi galant problem fault code 44
