I need some knowledge...
I'm still searching as I'm writing this,
https://mitsubishiforum.com/forum/4t...18/#post322390 Is my original post. Can someone please give me some guidance. (When no spark is an issue, can that itself be because of Anti Theft?) How do I know if my car has Anti Theft? I have a keyfob but I thought that was only to lock and unlock the car, not really an alarm. Radio works and car cranks just doesn't start. :/ There is fuel going into the rail, there is no spark and there is compression. Fuses work, Wiring is all hooked up right. I just can't figure out what's going on. (Using FASATEC) (I'm posting here because I see that there's more people active on these parts of the forum, I just need some guidance anything counts.) |
Is your car equipped with Keyless Entry and Start? Maybe it is not picking up the signal from the hand held unit.
Just a thought. Otherwise it could be a engine position sensor that has failed, but this is not a common failure. |
Originally Posted by Telferstr
(Post 322476)
