max boost
hi does anyone kno how much boost is safe to run on my 95 eclipse gsx motor is stock but rebuilt stock turbo mods r large front mount injen short ram manual boost controller greddy bov turbo manifold and exuast
thanks |
With those mods, you can only run 16psi because you'll run out of fuel.
The motor itself can handle 25 safely, when it's been maintained properly. If your engine has high miles, expect it to explode. |
what kind of fuel pump n all should i run and injectors
Depends what you what you want to do with the car.
i am going to do a fully built motor im probley going to get the brian crowor 272 cams i want to build it up n take it to the track like to c it do at least 12s
n probley go with the super 20g turbo
To do that, you're going to need:
DSMLink 800cc injectors AFPR Walbro 255 fuel pump Clutch Flywheel Maybe built engine Maybe built transmission. Turbo MBC Good front mount Boost gauge Wideband Data logger |
i have everything but the fuel pump dsm link clutch flywheel turbo injectors and afpr and data logger do u kno where i can find most of the parts and my front mount is 30 inches long 9 inches high n 2.5 inches thick u thing that would b big enuff
The size of the core doesn't really mean much. The quality, construction, and design of it is what matters.
You can find all that stuff by googling. |
can anyone tell ,e y my 2g eclipse would idle realy funny it idles high then low like someone is hitting the gas and letting of over n over check engine light was on had it checked and they said it was the idle control motor put a new one on and still didnt fix the problem
| All times are GMT -5. The time now is 06:45 AM. |
