new to gst
ok im fixing to get a 1999 eclipse gst with a long list of mods. Injen Intake
APEXI Turbo-back Exhaust Halo Headlights Greddy Type-S B.O.V Greddy Boost Controller(needs Grounded) has a manual one now Greddy Hard IC Pipes Turbo Timer Apexi Evo III 16G Turbo factory upgrade God Speed Front Mount Innercooler New Water Pump New Alternator New Timing Belt Balance Shaft Belt Cam Gear Seals Drilled And Slotted rotors all around 1200CC Injectors 255 Walbro Fuel Pump 3g revised lifters Dsm-ECU Tuner im wondering if this set up seems good. and what problems I should look forward to. also its set a 15lbs of boost. guy says its safe up to 18lbs. how much power would this set up make? its a 2.0 this is my first import of any kind. normaly a muscle car guy. figured id give the imports a shot. |
