oil filter bracket
When doing the 7 bolt to 6 bolt conversion the oil filter bracket or pipe does not have the oil pressure guage sending unit on it or a spot to mount one. All it has is the idiot light sender.
Questions; Does any one make a conversion kit as the 7 bolt oil filter bracket (pipe) will not fit on the 6 bolt? Can you use a turbo version with the oil cooler blocked off? If you use the stock 6 bolt without the pressure sensor will the computer allow the engine to run? Where does an aftermarket oil pressure gauge mount it's sensor? Thanks!!!!!! |
RE: oil filter bracket
guess no one knows[sm=jawdrop.gif]
yea sorry man, i have that same part to go on my new 6-bolt, but im still workin on what goes where on it
