Intake, Headers and Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
Exhaust in cabin outlander 2.2 D I D
Old Nov 9, 2023 | 10:25 AM
  #21
Róz's Avatar
Default Exhaust gas smell in the passenger compartment
Is your problem SOLVED? Please help me! I have the same problem. The engine compartment completely smells of exhaust gas. It is clear that the exhaust gas is leaking somewhere. They checked it at two service stations, but no leaks were found. Can you help?
Old Nov 9, 2023 | 10:34 AM
  #22
nickthesafe's Avatar
Yep, I'm on my third manifold now. Always cracks at the EGR return elbow/manifold flange weld joint - always!. Number three has now failed and i'm going to weld up the last one myself with some reinforcing gusset. The crack is so fine its hard to see, but a smoke test up the exhaust pipe should reveal it.
Old Nov 16, 2023 | 10:13 AM
  #23
Róz's Avatar
I have the same problem. Can you tell me what you changed? Where was the pipe cracked?
Old Nov 16, 2023 | 10:17 AM
  #24
Róz's Avatar
I have the same problem. Could you tell me where the crack was and which part needed to be replaced?
Old Nov 30, 2023 | 03:27 PM
  #25
24901049's Avatar
Originally Posted by DibbyDibbyDJ
The manifold is removed from above
, Disconnnect the plastic turbo hoses,
Remove metal bracket mounted to turbo that bolts to head
Unclip dpf sensor connectors (3)
remove bolts holding upper heat shield (3)
Undo 3 bolts holding DPF to turbo
Undo 2 12mm head size bolts under turbo holding it to a bracket ( not visible)
Undo 3 Bolts holding turbo to manifold
Remove turbo oil feed and return pipes.
Remove turbo
Undo bolts and nuts holding manifold to head
On the left side of the manifold the outlet to the EGR port is smaller. This is where it cracks all around the pipe. You will see black soot on the left side of the manifold
You can remove the lower DPF mounting bolt to make things easier, but this is only accessible from underneath.. This bolt secures the DPF to the transfer case.
Tailor your vehicle's exhaust sound to match your style with Spelab Auto Parts' exhaust cutout collection. Our valves offer a seamless way to switch between different tones, allowing you to enjoy a dynamic driving experience. Whether you're cruising the streets or revving on the highway, our cutout valves ensure you stand out. Explore the collection at spelabautoparts and redefine your vehicle's sound!
IGetting it rewelded is preferable to JB weld. I have never personally tried it
I agree, I've done something similar myself and re-welding helps.
Old Dec 1, 2023 | 04:22 PM
  #26
Róz's Avatar
Default Exhaust Manifold Crack at EGR pipe
Many thanks. Based on the instructions, I found the error.
Will this glue help for a long time?
https://technicqll.pl/en/produkt/ht-silicate/
Mitsu Outlander 4N14 GF6W 2.2D-4WD Exhaust Manifold Crack at EGR pipe
Old Dec 2, 2023 | 08:04 PM
  #27
DibbyDibbyDJ's Avatar
re welding is the cheapest option I dont think any adhesive would last long. Plus the crack is not easy to get to all the way round
Old Jan 7, 2024 | 07:43 AM
  #28
DPB's Avatar
DPB
Hi, Another one with the same problem. 3rd time..wow! When the manifold was replaced how long was it before the issue started again?
Love the car but debating on trading in due to this issue.
Thanks
Old Jan 7, 2024 | 01:45 PM
  #29
The Manifold was modified about 2 years ago, it has been redesigned, and no longer cracks.
Old Jan 7, 2024 | 02:36 PM
  #30
DPB's Avatar
DPB
Hi, Has the modified manifold been redesigned for older models? Mines a 2014 Diesel GX4.
