Intake, Headers and Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
Low idle when coming to a stop ('08 Lancer ES)
Old 01-23-2018, 07:18 PM
vizi0n's Avatar
Default Low idle when coming to a stop ('08 Lancer ES)
Hi everyone,
I have a 5 speed Lancer ES. It idles perflectly fine (cold, warm, anytime), but when coasting to a stop while holding the clutch pedal in, (and often braking at the same time) the RPM dips to 500 or so, the lights dim and the blower slows down.
Do you have any advice on such a problem? There are no codes or anything else wrong. On my Forester when this happened it was oil filling up my IACV but could it be the same on this car? And where is the IACV?
Thanks!
Old 01-27-2018, 11:09 PM
Luar's Avatar
Battery terminals, battery, throttle body, air sensor, much of these things tend to show when the rpm geos from a dramatic upvalue to a semi dormant mode. Habe you used any live odbii tools to see what your readings are? This can give you insite on what might be faulting. It could be many things more: intake hose, air filter, mass airflow sensors....
Old 01-27-2018, 11:41 PM
vizi0n's Avatar
I just noticed that my sentence was incomplete. After dipping to 500 rpm it goes back up to 750 and idles fine.
Battery and terminals/cables are good
I dont have anything to monitor the cars vital sensors unfortunately
Jayc71
13
05-19-2022 02:23 AM
dott
07-05-2010 09:00 PM
blue450yo
11-15-2008 06:35 PM
beavers2
09-15-2008 12:42 PM
Cuffy
02-02-2008 01:03 PM
Quick Reply: Low idle when coming to a stop ('08 Lancer ES)
