Intake, Headers and Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
Mitsubishi Pajero 3.8 GLS
Old Mar 1, 2017 | 12:55 PM
John Ireland's Avatar
Default Mitsubishi Pajero 3.8 GLS
I own a Mitsubishi Pajero 3.8 GLS Petrol.
In December of 2015 it went for its 180 000 km service and within approximately 1 300 kms later it developed a misfire and a sudden clucking sound from the engine. The vehicle was towed to the nearest agent who discovered that the butterfly on the one port had broken up and landed in the engine
On reporting this they also further stated that the bolt for the inlet manifold adjacent to the port where the butterfly broke was missing and which meant that the inlet manifold was not sealed correctly.
Is it possible that the lack of this bolt could lead to air being sucked in to this port resulting in excessive air being brought into this port from a different angle (from the side instead of above) with force causing the butterfly to break up from erratic operation and fall into the engine.
Could anyone confirm this. I have had a positive response from a Mitsubishi Expert but a different opinion from other general technicians.
Old Mar 1, 2017 | 03:37 PM
Benckj's Avatar
Can you explain what was done during the 180k service?
Fault does sound very suspicious but doubt if you will be able to 'prove' anything regardless of investigation.
jim
Old Mar 1, 2017 | 04:44 PM
The normal service which included the changing of the spark plugs and fitting a new cam belt. To change the spark plugs on this engine one has to remove the inlet manifold.
devilliers
Jan 3, 2015 11:33 AM
PeckyPeck
Jul 8, 2014 08:24 PM
Monterorider
Sep 20, 2013 11:17 PM
BillCosby
Feb 4, 2011 08:58 AM
Marcus360
Jun 4, 2008 06:40 AM
