speed meter need help
have anyone .....do a swap transmission for a 420a before, auto to manual .....??
RE: speed meter need help
Yes, its fairly easy.
yea i know ....is easy
but the funny thing is my speed meter doesnt work ... because i can't find the wires harness to connect to the manual trans help needed ...... |
You need to find out whether your setup uses mechanical speedo or electronic one. Most of the modern cars use electronic type, which is a little attachment (called sender) that has a gear mechanically connecting inside the gearbox and two/three wires going out to the speedo in the instrument cluster. Check for any hanging free connectors under your car around the gearbox.
It could be a broken sender too. |
well my 420a it use electronic .......so i will just check for the hanging wire .....thanks
