Interior What have you done to the inside of your ride? Customized it? Kept it super clean? Talk about it here.
Updated Pics of my finished interior
Old 10-08-2006, 12:06 AM
bdhunter's Avatar
Default Updated Pics of my finished interior
Anything I need to add?
Interior Specs:
- Complete Custom Interior
- Black Carpet
- Black with Red Accented Custom Floormats
- Black Painted Trim
- Black Headliner
- Stitched and Embroidered Vinyl Seats Front and Rear, Black and Red
- Black and Red Door Skins
- Matching Black and Red Shifter and Shift Boot
- Autometer Ultra-Lite Series Gages (Red backlight matched to stock)
- Boost Pressure (Pillar Mounted)
- Air/Fuel Ratio (Pillar Mounted)
- Exhaust Gas Temperature (Gage Cluster Mounted)
- Oil Pressure (Gage Cluster Mounted)
Stereo Specs:
- Alpine CDA-7840 Head Unit w/ AI-Shuttle Control
- Alpine ERA-G320 Digital Sound Field Processor
- Kicker Resolution Titanium Dome Tweeters (Pillar-Mount)
- Kicker 6½' Resolution Midbass (Front Doors)
- Kicker Resolution Crossovers (Front)
- Kicker 1' Titanium Dome Tweeters (Rear)
- Kicker 6½' Mid-bass (Rear)
- Kicker Resolution Crossovers (Rear)
- Kicker ZR240 Amplifier (Fronts)
- Kicker ZR240 Amplifier (Rears)
- Kicker ZR240 Amplifier (Sub)
- Kicker 12' Competition 25th Anniversary Ed. (Cast in Chrome)
- Custom Fiberglass Trunk, Sub is Inverted, Custom Amp & Wiring Racks (Built by Kicker rep)
- Platinum F3 Wiring, RCA's, Distribution Blocks, Fuse Holders, 1/0ga Power & Ground, etc
What do you think?
Old 10-08-2006, 12:27 AM
davidmitsusrock's Avatar
Default RE: Updated Pics of my finished interior
looks pretty damn nice
Old 10-08-2006, 01:45 AM
I would have cleaned it before taking the picture though
Old 10-08-2006, 11:50 AM
bdhunter's Avatar
:-p was in a hurry, but like i said, i'd get pics on here!
Old 10-08-2006, 04:28 PM
Holy GOD is that shift **** tall enought jesus. that thing is almost half way to the roof hahaha. all I would say is lose the ricer A\F gauge and get a wideband those AF gauges do nothing but look pretty
Old 10-08-2006, 11:29 PM
bdhunter's Avatar
Engine Specs:
- 2.0L 4cyl DOHC 16V EFI Turbo
- 1998 420A Engine bored and honed .020" over
- Crower Billet Connecting Rods, Bushed for .827" floating pin
- JE Forged Pistons with pins and locks, 8.5:1 (.020" over)
- JE Forged Piston Ring Set
- MLS Headgasket
- Hahn RaceCraft Super 20G Turbocharger
- Synapse Engineering Missing Link
- Fluidyne Radiator
- RRE Catch Can
- APEX'i Power Intake
- APEX'i Front Mount Intercooler
- Mandrel Bent and Powdercoated Intercooler Piping
- Powdercoated: Valve Cover, Intake Manifold, Turbo Housing, Blow Off Valve, Strut Tower Bar
Mounts, Thermostat Housing, Radiator Mounting Brackets, Heater Hose Hard Lines, etc.
- Thermal-flex Reinforced Silicone Intercooler Connectors
- Ported, Polished, and Gasket Matched Intake Manifold
- Turbo-Xs Type H Blow Off Valve
- Hahn RaceCraft Exhaust Manifold for the Super 20G Turbocharger (ceramic coated)
- Custom Mandrel Bent 3' Down-pipe by Tachyon Performance
- Custom 3' Mandrel Bent Exhaust by Tachyon Performance
- Magnaflow Performance Race Series Muffler
- Dynomax Race Magnum Bullet Muffler [In-line]
- Unorthodox Racing 30% Underdrive Crank Pulley
- Unorthodox Racing Adjustable Cam Gears
- Clutchmasters Stage 4 Ceramic Modular Clutch
- Stillen Short Throw Shifter
- Vitek Spark Plug Wires
- NGK Spark Plugs (BKR7E)
- MSD DIS-2 Ignition System
- EverStart Maxx 1000 Battery
- Hahn RaceCraft 'PortFueler' Fuel System
- Bosch 1:1 Fuel Pressure Regulator
- Stainless Steel Braided Fuel Lines
- Accel High Performance Fuel Injectors
- In-line Fuel Pump from Hahn RaceCraft
- Greddy Profec-B Electronic Boost Controller
- Greddy Turbo Timer
- Stainless Steel Braided Oil line
Suspension Specs:
- 18" x 8" Enkei Wun-Gun Rims
- Yokohama Parada Spec-2 235/40/z18 Tires
- Tokiko Illumina 5 Way Adjustable Shocks & Struts
- Eibach Pro-Kit Sport Springs
- Stillen Camber Kits
- Stillen Front Strut Tower Brace
- Stillen Rear Strut Tower Brace
- Stillen Cross drilled and Slotted Rotors (Front)
- Stillen AP Racing 4 Piston Calipers (Front)
- Stillen High Performance Brake Pads (Front)
- Stillen Stainless Steel Braided Brake Lines (Front)
- Stillen Cross Drilled Rotors (Rear)
- Stillen Stainless Steel Braided Brake Lines (Rear)
- Metal Matrix Brake Pads (Rear)
Body Specs:
- Stillen Front Fascia
- Stillen Commando Wing
- Carbon Fiber Hood (paint matched to body color)
- Dynamat Hoodliner
- Clear Front Side Markers
- AngelEye Chrome Projector Headlamps
- Original Tail Lights
- Tinted Windows
- External Antenna removed and internal put in
Stereo Specs:
- Platinum F3 Wiring, RCA's, Distribution Blocks, Fuse Holders, 1/0ga Power & Ground, etc.
Interior Specs:
- Black Carpet
- Black Headliner
Old 11-03-2006, 04:24 AM
nice i like the way the trunk is set up!!
Old 11-03-2006, 10:03 PM
i think you need to add me in the drivers seat.lol. Its a nice car. I like your audio layout.
zontarh
09-15-2010 11:51 AM
Sanguinius
10-18-2007 05:19 PM
2nd g eclipse gst
04-16-2007 08:26 PM
MrJayDeeOne
02-09-2006 12:15 PM
Quick Reply: Updated Pics of my finished interior
