ASX doesn't start
Old Feb 13, 2013 | 08:05 PM
chromeasx's Avatar
Default ASX doesn't start
Hi guys im new here , and have an issue with my asx , it wont start , was working perfectly i park it on front of my house and next morning nothing , batery is ok ,engine turns but sound like if the timing chain was broke , tomorrow i'm going to take it to the dealer but want to know "if you can suggest of course " posible causes just to see what the dealer tells me , you know how dealers are and dont want to be another "victim". Thanks any help will be apreciated.
Old Feb 14, 2013 | 04:57 AM
Jeff Collision's Avatar
Make sure that you have enough gas in your ASX. Check to see if your fuel pump is turning on. Find out if your engine is getting gas to it. Sometimes a plugged fuel filter or a problem with the fuel injectors can prevent your engine from getting any gasoline. Finally, determine whether the spark plugs are firing.
Old Feb 20, 2013 | 06:48 AM
chromeasx's Avatar
Thanks , i took it to the dealer and they say that it works perfectly , they told me that they turn on the key and it just start , i dont know what to think but its been working fine so far so......... thanks again for your help !!!!!!
Old Aug 12, 2013 | 02:28 PM
whizzy's Avatar
Default Recall in Holland
In Holland we had a recall for this problem.
Mine was fixt in march this year, the same problem as you discribe.
They have placed a new camshaft sprocket.
Hope this helps you to get yours fixt to.
Old May 16, 2024 | 03:45 PM
Glzedge's Avatar
Default Resolution
Good evening,
I am having the same issue, did you manage to identify and resolve the issue?
Thanks
davedesmo
13
Sep 28, 2007 06:10 PM
davedesmo
Sep 27, 2007 08:37 AM
1995MONTYSR
Sep 1, 2007 10:54 PM
Marah
15
Feb 28, 2007 07:58 AM
deltadave
Dec 6, 2006 08:09 PM
