Battery drain
Hi everyone I have a 2013 Mitsubishi rvr and I have a very bad battery draw basically I'm getting 0.135A of draw which is causing my battery to die once a week or sometimes once a month it varies I have disconnected every fuse and relay inside the engine compartment and I end of the draw does not drop it stays consistent any help would be very much appreciated thank you very much I am located in Canada that means anything
I have isolated the draw to the fusible link and one of the cables that 80 amp cable is drawing however I do not have wire diagram so I do not know where that any amp fusible link goes to |
| All times are GMT -5. The time now is 09:49 AM. |
